Project Springtime or Busted!!!
broncoitis
broncoitis
Ok, got some more stuff done today and had a little bit of a setback to some extent.
Mounted the condenser to the radiator and I really like how it turned out. If you ask me I think that it looks really clean. Cannot even see the mounting bracket barely and once I put the cover over the top of the radiator it will look really good. ;D
I also got the under dash console repainted and let me tell you, the second time was the charm for sure. It looks a Thousand times better than the first time I painted it! To top things off, had a different paint place mix me up a Spray Bomb of matching color and it is practically a PERFECT MATCH compared to the original stuff that I used. I know where im going in the future! ;D:cool::);)
Also started the process of getting the radiator and condenser to fit into the stock location. Don't want to go through the hassel of bending the cross piece to make things fit so I will just trim a little of the fat and it will fit like a glove. Unfortunately, that is where the problem happened today. While grinding on the support I accidently got a little careless and the flap wheel knocked off the skin and put a decent cut in the top of my dominant thumb! %) OUCH!!!! That hurt a little but some peroxide, pressure, crazy glue and bandaids got things patched up enough for now! :)
Giving it a rest till tomorrow so that I can try and get some more accomplished.
Here are some pics of the before and after pics of the console and the condenser and how it looks mounted to the radiator. Granted nothing earth shattering here just like how it looks and I think you guys and gals will as well.
As always, thanks for lookin! :cool:
tasker
all knowing of nothing
NH
all i can say it "wow'' ......amazing build....
broncoitis
broncoitis
Thanks Tasker! Nothing really earth shattering. Just trying to keep it looking neat as always. Although I do appreciate your comments.
Gonna work on some different stuff today that I can hopefully get alot done. Like:
Driveshafts, put new yokes on D20, reinstall driverside exhaust, Finish bolting up tranny crossmember, admire paint on lower under dash consol, fill up the diffs and other mechanicals with fluid (Don't wanna overlook that accidently), etc......
Should be doable with the injured thumb and all! LOL!!! ;D
Thanks for th
stupidboy
My wifes porn star.
Morrisdale Pa.
Are you using the wiring that is in the efi harness for the a/c or is it a stand alone harness that comes with the a/c? I'm reconfiguring my mustang harness instead of buying the RJM harness and it has wires for a/c in it and I am wondering if I will need to keep them in there or will be able to have a/c in the future without.
NY-Bronco
Resident Dipstick
Weehawken, NJ
He is using the Centech for the main harness, RJM for the EFI harness and the vintage air has its own harness.
englewoodcowboy
Lick Creek Restorations
Looks great! Is that the condensor VA provides or did you spec it? I have heard that cooling broncos becomes a problem with too small of a condensor and it looks as if you have room for a larger one?
broncoitis
broncoitis
I used the same condenser that BC Broncos uses in their kits. I have heard the same thing about cooling the bronco. I think that the problem is as much from the condenser size to the airflow actually going through the Condenser to cool it off. I think that makes sense. LOL! ;D
I think that the overall Key to the puzzle could be the Shroud around the fan and how it is attached to the radiator. I guess I will find out but yeah there is a bit more room i guess!
backpain
Room for a larger one? Well....depends....
If you run a stock hood latch or even maintain the stock latch bracketry there is not room for a much larger condenser in terms of total face surface area.
A condenser the size of the radiator only works with the stock latch if you can fit it between radiator and core support. To get that large, you would still have to re-engineer the radiator mounts.
You could mount a condenser sideways (more wide than tall) to max out available horizontal real estate, but you ultimately run into boundaries on the sides (fender braces, light buckets, mechanicals, etc), top and bottom (frame rails, hood clearance) that leave you relatively the same size as the BC until - until/unless that hood latch goes away or is somehow relocated on an extended core support so you can use the area between the core support and grill or more area is created between the radiator and core support. The stock hood latch interferes significantly with clearance between a stock core support and grill.
Other options - move the radiator closer to the engine, put it behind the radiator, extend your fenders and move the grill forward, etc. Most people don't like those options either.
broncoitis
broncoitis
Backpain,
All good points! I really think the big key is making sure that air is going through the condenser and not around it. The condenser needs to be mounted as close to the radiator as possible. Ideally, I have seen places setting up the gap between the radiator and condenser with a piece of cardboard between them. They put them that close.
Mine is currently mounted as close as this setup will allow. Should be okay!
Another thing that people fail to realize is that the DRIER also needs to be mounted in an open area. It is not a coincedence that the drier is usually mounted on the front side of the core support of most vehicles. That is where I plan on mounting mine.
NY-Bronco
Resident Dipstick
Weehawken, NJ
Backpain,
Why would the dryer need to be mounted in an open area being that it does not require airflow. Think of the dryer like the silica packets to keep various products dry. Also do not open the dryer until you are ready to install. It will suck moisture right out of the air rendering it useless.
As far as the condenser goes just mount it in a similar fashion that BC Broncos has it. They did their homework and it works quite well.
backpain
. . . Another thing that people fail to realize is that the DRIER also needs to be mounted in an open area. It is not a coincedence that the drier is usually mounted on the front side of the core support of most vehicles. That is where I plan on mounting mine.
Open area or just shielded from heat? Maybe also with reasonable air flow? Not sure where mine is going yet. Most factory drier/accumulators are in the engine bay, right? ..or maybe that's only when it's a low pressure side accumulator . .
If you can't get your condenser as close to the radiator as you want, a little metal strip on each side to "shroud" it to the radiator . . . maybe?
NY-Bronco
Resident Dipstick
Weehawken, NJ
If you can't get yours as close as you want, a little metal strip on each side to "shroud" it to the radiator . . . maybe?
suggested area is next to the battery.
backpain
mine will likely end up behind a cover somewhere
a shame to waste the chrome plated version out of sight, but I didn't plan very well when I bought the pieces
NY-Bronco
Resident Dipstick
Weehawken, NJ
I dont think its a waste. Just look at my engine. It all chromed out. But I did that for me. Rarely does anyone get to see it. Just the Bronco Brothers really.
