Project Springtime or Busted!!!
backpain
yeah, but mine is chrome and I am going to hide it from even myself. one of those invisible upgrades. maybe I'll make a peep hole to see it :)
broncoitis
broncoitis
You guys are TOO Funny!!! LMAO!!
I would still mount the drier in an open area of the engine compartment. My plan is to put mine on the radiator core support somewhere hopefully with good access.
Backpain,
If you got the bling, show it off. There are a couple of places that you can mount the drier aside from behind the battery.
Herman,
Good points and I see you point! However, I still would like to have the drier in an area that gets some airflow even if it doesn't need it. Thats just me though.
broncoitis
broncoitis
Worked on alot of different things on the truck today!
Okay, one of the things that I messed around with was the lower radiator hose coming off the explorer water pump. Was playing around with the lower radiator hose off of the 02 F250 Super Duty 7.3 PSD. Although this hose is supposed to fit pretty well, I personally did not like the way that the hose fit my current application at all! I think I wasted $30 bucks because the hose is unreturnable at this point. :cry:
The reason for the disappointment is that although this hose may work well with a stock style V-Belt configuration I did not like the way it fit with the explorer serpentine setup at all that I am using. It seems to be TOO close to the lower pulley on the Serp setup for my liking. :( Oh well, I am gonna get the Radiator that is designed to work with this setup the right way and not continue to try and fit a SQUARE PEG into a ROUND HOLE!
I have a nice aluminum Howe Radiator from JBG for sale if anyone is interested that is in really good shape! Let me know.
broncoitis
broncoitis
Ok, that was the big disappointment/frustration of the day.
Hooked up the vents for the VA. Very happy with the airflow coming out of the vents. Keeping warm or cool should not be a problem! :cool:
Also installed the under dash console permanently for the forseeable future. Anything that needs to be done can be done with the console in place at this point. ;D
Filled up the D44, D20 and the 9in with Lucas 80w-90 as per explorers suggestion. I can confirm that the 9in holds a whole hell of alot of gear oil! In fact, twice as much as the D44 it seemed. Hopefully that is normal! :eek:
Also got the driver side of my dual exhaust hooked back up.
I have to start buttoning up the little odds and ends if I ever wanna get this on the road so that is what I am trying to do. Hopefully alot of things will get crossed off the list this week. :)
HGM
Senoia, Ga.
Why would the dryer need to be mounted in an open area being that it does not require airflow. Think of the dryer like the silica packets to keep various products dry. Also do not open the dryer until you are ready to install. It will suck moisture right out of the air rendering it useless.
The purpose of the drier is actually a little more than just to "dry" the system. Yes, the desicant is there to absorb the small amount of moisture left. But, more importantly, its there as a resivior to contain any hi pressure vapor that may not have "condensed" in the condensor. The idea is that as the vapor comes out of the compressor, it needs to be cooled (20* or so) and allowed to condense.. If the process is not complete, it will finish in the drier (in a lower heat area, preferably with good airflow). This way, it assures a "pure" liquid flow to the expansion valve/evaporator. Vapor doesnt evaporate well;D.. If everything is sized properly, the condensor should be able to do the majority of the work.
broncoitis
broncoitis
Finally reinstalled the Driver side exhaust. Although it is there now, It will eventually be removed and converted to a single exhaust outlet on the passenger side with the Y pipe from BC Broncos.
Also was able to get the new timing marks onto my Harmonic balancer. Hopefully they are pretty close. Used the markings off of an Explorer balancer as a reference so should be ok hopefully. %)
Also installed my Front Tom Wood's Driveshaft and it sure is Purdy! Hopefully it will give many years of reliable service with regular maintenance. ;D
I was also able to finally finish installing the Tranny Crossmember of the NV3550 conversion that I started in 2006. Been a couple of years but I thought I should finally button that up! LOL!!! :eek:
broncoitis
broncoitis
Got a little more done tonight! Got the rear Driveshaft installed and am working on finishing up the VA A/C lines so that I can put that baby to rest once and for all.
Also, most of the wiring harness is back in place so the only thing really left to do is install the steering column and accelerator pedal.
However, the column will have to wait till the accelerator pedal is in place. It will just be in the way.
Another thing that I started working on is the Power Steering and Hydroboost lines. I was hoping that I would be able to reuse my current resevoir that I got from PSC but is doesn't look like it is gonna work. So I either have to use the stock explorer resevoir or find another resevoir that will work! %)
Another thing that I looked at tonight is mounting the VA Drier on the front of the radiator support. Not sure if there is gonna be enough room to do it or not at this point! ?:? Will see how it looks tomorrow with the grill held in place before I drill any more mounting holes!
Seems like everything is having to be replaced. It is kinda getting frustrating!
broncoitis
broncoitis
Ok, so I am wrenching on the truck tonight in the driveway with the Door open and I catch something out of the corner of my eye walking fairly close to me across the driveway. I turn around to see what it is and its a SKUNK!!! :eek: Definitely didn't panic but was definitely suprised no doubt!!!!
Anyway, back to the important stuff.
Made some good progress tonight with getting the remainder of the A/C lines squared away. Really like the way that they will be run as well.
Basically they are gonna be hardly noticeable for the most part. Gonna hopefully get that finished up tomorrow.
I was able to get the Drier mounted to the radiator support and I like the position of it for the most part. Only downfall would be if there is ever a problem with it. Would be pretty damn near impossible to remove. However, it fits nice and snug where it is and the Driers are usually not a problem. ;D
englewoodcowboy
Lick Creek Restorations
I think your drier location will work fine. My 68 stang had factory air and I am pretty sure it was on the fron to the core support, had to remove the grill to get to it, shouldnt be too big a deal and you shouldnt need to access it too often.
Are you going to try and make Gore? Would love 2 see this thing in person.
A quick suggestion if you havn't installed your balancer yet, mask the timing marks off and shoot a couple coats of black (to somewhat level it out) then un-mask and clear coat it. I like the marks but dont care for stickers that are in the front and on a moving object (they tend to become illegible after a few years or disappear completey). I think that will seal it up well so if you pressure wash it they will be there in the future. Just my anal-retentive $0.02 worth.... lol
broncoitis
broncoitis
Englewood,
I think that I will do that! I was just curious if the clear would damage the sticker with some chemical reaction! The marks I have are from an explorer balancer and they are quite easy to see! Just put them in a vise next to eachother and transfered them over with a square so they should be pretty accurate.
I don't really wanna take the ballancer off again but to be honest, the top of the balancer and bottom of the water pump/timing chain cover are ridiculously close. :eek: So close that it looks like they are actually in contact with eachother so I will also hit it with a flap disk while the balancer is off and make a little more room so that it isn't so close!
As for Gore, I am definitely gonna try and make it down there in June! Would lolve to meet you and some of the others! ;D
broncoitis
broncoitis
Ok, a little bummed out about not going up to BYOB! Looked like it was a blast and alot of nice trucks to check out. Oh well! Maybe in the Fall I will be able to make it up there if they have another get together. ;D
Anyways, back to the project! :)
Was able to get some more things accomplished today. Fabbed up a mounting bracket for my P/S resevoir to attach it to the Explorer Serp Mounting bracket. Came out pretty good for the most part but my Welding needs some practice. %)
Honestly tempted to make another because I played with my gas settings and the welds got alot nicer! Maybe tomorrow if I have time. ;D
Was also able to get the Accelerator and the rest of the Throttle Linkage reinstalled. Currently running the BC Broncos Carb setup that I modified to work with the EFI by making my own brackets. Will make adjustments and eventually rebuild the them once all the bugs are figured out. I was hoping to get things right the first time but that was wishfull thinking on my part!
Unfortunately there is a little bit more friction in the current setup than I would like. Gonna mess around with it tomorrow to see what I can figure out but I have some ideas in mind to make things smoother!
Wanted to finish up the A/C lines but that will get done early this coming week along with the P/S lines. Had to have some stuff made that I am currently not capable of making so that is the delay on that right now!
Still have to mount up the coil, MAF Sensor w/filter and get the Radiator hooked up. Don't really want to pony up the cash for a new EFI Radiator but if I can't get this plumbed up to my liking then that will be the eventual solution.
NY-Bronco
Resident Dipstick
Weehawken, NJ
The Peronis brought the ambulance and another one that was all stock. Beautifully restored Bronco with everything the way its supposed to be. And guess where the dryer is? Same place you chose:
broncoitis
broncoitis
Yeah right! I noticed that pic you posted last night. Had no idea how/where they located them in the past but My hose is going through the core support the same way and snaking behind the battery out of sight. ;D
broncoitis
broncoitis
Today was a cleaning day in the garage! Too much crap all over the place and it had to get cleaned up a bit so not much to report!
Decided to remake the resevoir bracket for the P/S and Hydroboost setup. Even though the first bracket would have been fine, I like how the second bracket turned out much better. ;D Gonna sandblast and paint the bracket tomorrow and hopefully get it mounted on Tuesday for good.
Messed around with the linkage but not a whole lot of progress there to report.
Also gonna blast off the bracket to mount the coil tomorrow and get that mounted up on Tuesday as well hopefully.
Also have to configure a crossover tube for the lower radiator hose. If I can't come up with something then I will switch to the correct radiator. :(
Here are some pics of the bracket that I fabbed up and how the resevoir will look mounted up.
broncoitis
broncoitis
Didn't get much done today! Basically worked on getting some of the new parts painted up for install and what not. Also messed with the Throttle linkage and I think that it is pretty good now for the most part! There is still a little bit of drag in the system but it is definitely better than it was for sure. ;D
Gotta figure out where to mount the coil! Not really sure where to put it at this point but I would like to get that squared away tomorrow hopefully along with the lower hose for the radiator!
Post some pics if anybody has a suggestion that reads this thread. Thanks! :D
broncoitis
broncoitis
jlake4130,
Thanks!
The Resevior is an older one from PSC! Hoping that it isn't too high for the hood that I am running where it's mounted. Got my fingers crossed! :cool:
stupidboy
My wifes porn star.
Morrisdale Pa.
Is the a/c tubes connected to the compressor yet? Looks like your using the explorer compressor and I want to know what mods you made to hook up to vintage air lines?
broncoitis
broncoitis
Pat,
I am using the explorer compressor. Currently having the mounting block fabbed up to mount the VA lines. The high pressure side is going to run along the side and be a #8 and point toward the front. The return number 10 is going to point straight back toward the firewall. I will post a pic of the mounting block when I get it back.
The line pointing out the front has to clear the Resevoir. Hopefully he can get it right from the pics I sent him. %)
broncoitis
broncoitis
Nothing major got done today! Just finished up modifying the Mustang brackey to mount the coil in the bronco. That is it! :(
Everything helps though. Its the little things that take the most fricken time! %)
