Project: Wolf in Sheep's Clothing
BruiserOutdoors
BruiserOutdoors
Prepping parts for clear coat.
BruiserOutdoors
BruiserOutdoors
cleared. I like contrast in color between the transmission and transfer cases. I almost painted the transfer case "cast blast" cast iron color, but glad I didn't. the clear coat darkened it up a bit.
My reasoning for going to this effort is for future cleanliness and maintenance. hoping these parts wipe down quick and easily after time on the trail. And to avoid corrosion. I have noticed on other rigs that zinc coated parts seem to corrode after a couple days on the sand. Hoping this helps keep a bright and smooth finish.
BruiserOutdoors
BruiserOutdoors
I really didn't want any leftover sand inside the frame! Also built a make-shift rotisserie to help with painting the frame. it didnt rotate too great (got bound up).
BruiserOutdoors
BruiserOutdoors
epoxy primer. absolutely destroyed my shop with overspray.. The epoxy laid down pretty well. Eastwood product.
BruiserOutdoors
BruiserOutdoors
2k ceramic chassis black. Wasn't too thrilled with the outcome. So I resprayed it (first go around had alot of overspray). Hoping the second try turns out better.
BruiserOutdoors
BruiserOutdoors
frame's looking sharp.. Nice work
thanks. ended up respraying another coat since the last photos because I wasn't quite thrilled with the outcome.
It was painful putting that much effort into a frame with such ugly factory welds. I am surprised the abuse these bronco frames can take despite the ugly careless welding.
BruiserOutdoors
BruiserOutdoors
installed the duff long arms. Initially before final torque, the radius arms touched the ground at the same time. as I torqued the head unit to the arm, it picked up the passenger side arm 0.25". I loosened things and had a helper put pressure on the arm, as I re-torqued everything. no change.
is 0.25" "good enough"? yes I know it will cause bronco lean if they don't touch but wasn't sure what the tolerance on this was. will I ever notice that 0.25"? I suppose 0.25" at the back of the arm is more like 1" + at the axle?
my only other idea (as I typed this out), is to cheat the drivers side arm on a 2x4", and put more pressure on the passenger arm as I retorque things down. open to thoughts and suggestions.
sprdv1
REBEL
right :) how much time you reckon you got into the frame so far? IF I ever have enuf room, thought about doing that myself, ground up. Prob be a couple yrs tho
BruiserOutdoors
BruiserOutdoors
not really sure. here is a guess:
I probably have 1.5 hours filling extra holes. 3 hours transporting between fabricator, and sand blaster. Sand blaster was only $250, saved me a bunch of hassle getting the frame prepped. Fabricator was hired to add the steering box reinforcement and radius arm mounts, and remove a bunch of extra stuff the previous owner added. He spent 12 hours on it.
3 hours of paint prep including prep to setup my shop. 3 hours to paint primer. 8-12 hours for top coat layers.
sprdv1
REBEL
appreciate ya.. time, money and patience right
badkarma
looking Great!! I was in El Paso on Border detail for 60 days so was out of the loop. I am finally feeling a little back to normal. Came back and drove wife down to Orlando for cheap trick show i have to say with the 4 link it actually takes off at 90 mph. highway is absolutely amazing 80 mph cruising at 2300 rpm. no drone from the 347 in higher RPM is a godsend.
BruiserOutdoors
BruiserOutdoors
So with the help of a buddy, we got the arms to touch the ground at the same time.
When we went to rotate the duff long arms into their mounts, the arms had to be forced apart, the arms were too narrow to slide into the mounts. Is this normal? @Monster Mike
