Ps fluid
SteveL
Huge chevy guy
Hawthorne ca
Just finishing up hydroboost swap on the 72. New pump, hydroboost unit and maybe a bc cooler. What's the best fluid to run? If going synthetic does the old ps fluid need to be completely bled from the existing parts of the system?
garberz
Bronco Influencer
Conejo Valley, Ca.
Lee’s Power Steering always recommend clear GM PS fluid. WildHorses, Jeff Howe and Steerco/AGR recommend Swepco 715. I just installed an Extreme duty Saginaw pump from PSC, the tag on it said, “ do not use ATF or synthetic fluid”. I’ve been using Swepco in the last few pump upgrades that I’ve done.
Mark
sykanr0ng
I would definitely drain it and possibly flush it before putting new fluid.
Who knows what kind of residue or dirt is in there now?
bronco italiano
Swepco oils if you can. I use their engine oil (306), Gear oil (201), pwr strg fluid (715) and grease too.
Glass Pony
Sussex County Delaware
I'm in the middle of a Hydroboost install myself. I had Amsoil in it so that is what I'm going to go back to. Hydatech called for GM #1052884 and #12345866 (cold climate) in the 16 oz. sizes.
