Pulley alignment
jdeignan
Hey guys-
I installed the Pro Street harmonic balancer from WH.
My 302 is from 87, so I got the 50oz.
It came with odd spacers between the pulley, and the balancer I removed didnt have them.
Alignment looked great until i fired it up and watched the belt try and walk itself off.
Anyone have any suggestions on how to further space the crank pulley so the belt aligns?
Joe
WILDHORSES
USA
Hi Joe, I don't like what I see there. I have never used the spacers but I suppose that is what Pro Race intended. Let's go back to the basics. Is there a reason you were changing from the other balancer? Was every thing lined up correctly with the old one?
Here's the if it were me and I was determined to use the Pro Street balancer answer. I would add washer/s until I got the proper spacing and use that measurement to make a billet spacer complete with pulley centering. I know someone is thinking you shouldn't have to, I agree.
I think most of the time people are putting these on the 50oz motors and running the stock Bronco v-belt set ups. We would defiantly be interested to hear and see what others have done. Maybe there is a custom pulley out there we are not aware of. You can send it back for full refund if you decide it's not going to work.
Jim
JWMcCrary
I have this same balancer, bought it in 2005 and ran it on a 50oz balanced stroker until 2019. I just recently (early 2020) swapped the weight to 28oz and bought the serp pulley from WH for the explorer conversion on my 75 with a 302. I did not use the spacers behind the pulley on either bronco. I did use the spacers but it was behind the bolts, basically thick washers, due to the supplied bolt lengths. Worked great and still working great. Here's a pic on the 302.
jdeignan
jdeignan
I appreciate the response. I noticed my power steering pulley was actually the culprit, and was pulling the crank off track. Made modifications to it and everything aligned.
However, I too dont love the supplied spacers from ProStreet. I think Summit sells an adapter (that looks like the front of my previous balancer) that I could use IF it bolts on to it correctly. It would be a solid spacing vs 4 long bolts. Ill look for a link- but Ive seen it.
Lastly, I changed the balancer for clear markings, and because I had a hunch my old balancer was going bad.
WILDHORSES
USA
Thanks for the update. I like the marking on this balancer as well. Let us know if you change to the spacer.
Jim
