jjintn
Replaced the v-belts on my '66 and having a problem getting the power steering pump pulley to line up. It sticks forward about 1/4" further than the crank/water pump. Any quick tips on getting things to line up?
Also, I replaced the belts with the same ones the PO had on there. I've got one belt wrapping the PS pump, water pump, crank, and alternator, and a one belt that wraps all but the power steering pump. From what I've read on here the only reason to have dual belts on the alternator is if it's a high output. Can anyone see anything in the pics that explains why the PO might have done this, or any reason to switch to a stock belt setup?
Thanks,
J
Thanks,
J
