im about to yank the 5.0 out of my 88 LSC, but before i do that, i want to eliminate some of the unneeded stuff. Id like to remove the a/c and the smog pump.
Summit has a whole bunch of stuff, but im not sure which is the way to go. the smog pump stuff seems simple enough, and works with a stock serpentine belt.
the a/c is the problem area. ford racing has an a/c eliminator bracket which moves the power steering pump AC up to where the a/c once was. can I use the pump from the bronco, or do i have to use the pump from the lincoln? is there a different option that i havent thought of?
thanks
Scott
You can remove the smog pump without adding the pulley, no need to buy anything but a shorter belt.
For the AC probably the cheapest route is the
Ford Racing AC eliminator kit or the
Trick Flow kit both are just over $30. The Ford racing looks like the better option and keeps the tensioner in the stock location.
You could also just leave the AC compressor and use it for on board air, that's what I did. I am also using
BCB all in one PS bracket to run a Saginaw pump and a Sanden compressor, The
Lars Saginaw bracket from WH works well too! If you get the BCB bracket be sure to get the needed PS pulley from them as well (it has a odd offset and is a pain to find elsewhere), the Lars bracket uses the common serpentine PS pulley. The Ford pulley won't fit on Saginaw pumps it has s smaller shaft size.
If you haven't figured it out already the LSC uses a different alternator and bracket than the Mustangs, they look almost the same. The LSC bracket fits a large body 1G and the mustangs fit a small body 2G. You can run a small body 2g or 3g if you make a bracket to to take up the space on the upper mounting ear. I did this for a while with a 2G, but when I upgraded to a 3G I ordered a large body, hoping it would fit. The large body 3G has the right spacing but the ear is thicker. To make the large body fit you either need to machine the ear down thinner or make a bracket as I did shown in the pictures. This is actually the same piece of 1" x1/4" aluminum I used for the 2G, but the 2G required some spacers to get it to align. Or you can keep the externally regulated 1G which actually puts out decent amperage (around 100amps) and pretty close to that at idle. The only downside is you have to use the external voltage regulator and all the wiring for it and the peak amperage output is a less than you get from a 3G.
I also eliminated the smog pump and haven't noticed any adverse effects.
