Pulling engine codes
Bronc0311
Austin
Trying to pull codes from my eec-lV.. I'm using the obd-1 code puller. I have followed the instructions via the manual however I'm only able to pull key on engine off codes. It won't pull the memory code or key on engine on code. What Am I doing wromg
Nickm1024cobra
Chicago Burbs
Did it pass the key on engine off test with code 11? There are specific codes you must fix before doing the key on engine on test.
When doing the key on engine off codes, it will first send any codes kicked out while running the key on, engine off test. Then...it will send a separator code (i believe code 10), then send continuous memory codes. Thats how you get those codes.
After using OBD 1 scanners for the last 10 years I finally got a different one i love.
Well worth the money, no more listening for beeps and lights, it converts them to the actual code.
https://www.amazon.com/INNOVA-3145-Ford-Digital-Reader/dp/B000EW0KHW
B
Bronc0311
Austin
Yea I ran the koeo scan several times.. It did not give the pass (11) code..it did spit out several codes which I wrote down however it never gave the separations code (10) and then move on to the continuous memory codes
Ourobos
Big Island Hawaii
Bad scanner? Have you tried a 12v light and a jumper wire in the harness?
EFI Guy
TheEFIguy@gmail
BFE
If you are getting code 67 during KOEO you will not be able to do the KOER test. You'll need to ground pin 30 on the PCM and it should let you do KOER tests.
