mustangtoby
Got this Bronco 2 1/2 weeks ago, and it drove straight down the road. Wanders all over, but didn't pull any one direction. Would turn all the way to the left, but not to the right. It hit the stop on the left, but maxed out the steering box on the right. So I bought the indexed drop pitman arm from Wild Horses and installed it last weekend. Centered the tires, pulled the pitman arm, centered the steering wheel, installed the new pitman arm (has no "keyway"), and now it will hit the stops turning right and left, just like it should. Now when I drive it at highway speeds it pulls hard to the left, enough that it is uncomfortable to drive it more than 10 miles or so. I can't see why centering the steering box would cause this, but it didn't do it before.
This Bronco has a 3 1/2" lift, power steering with 76 tie rod "y-style", disc brake dana 44. The tires aren't cupped, wheel bearings are tight, new tie rod ends, 32" BFG atko at 3/4 tread, Power brakes, No shimmy or anything else.
My next step would be to put the old pitman arm back on and see if it quits pulling, then I gess I would know that it's causing the problem. Any ideas?
