I'm sure there has been alot written about this but I just finished rebuilding a 351W and have it installed. The problem is I used the standard 4 bolt damper and it has a longer offset ( 3/4 " ) than the stock. If I use the stock 351 bottom pully I will run out of room to the radiator. I don't want to change dampers because it was balanced with the assembly. Is there a bottom pully out there (4-bolt) with only a 1/2" offset (2-groove) that will match up with my stock water pump pully? - Paul
