Speed with a ram is all about volume. There are pleanty of stock pumps that make enough volume and pressure but they have to be tweaked some to make it happen. As Brian said the fitting in the back or bottom of the pump must be drilled out to .188 and a smaller pulley installed to get the volume up, the only exception is some larger pumps don’t need the pulley, but they all need the fitting drilled out.
