Quarter pannel guards
ctowery
Wellington Nevada
Question is , do I need them if the hardest trail I plan to go on is the Rubicon ? All my heep buddies say I will destroy the rear quarters on the Rubicon. What do youall think. I have a 5 in lift 2 in body lift and 35s all locked up, AOD and 4.88s. Thanks
BoltBuster
I would love to go there,never have but seen plenty of pictures to make me think I should consider alot of advice on all rock protection.
Anyhow the guards only help in some cases ;D
Have fun post pics-
SteveL
Huge chevy guy
Hawthorne ca
I think a wrap around bumper would do a better job. The rear quarter protection I've seen is all aluminum for show.
howiebilt
Bronco Buddah
Newton
WH has the steel ones ;)
Quarter Panel Guards
The ultimate in quarter panel protection, the Wild Horses quarter panel guards will help save the sheet metal or cover up the damage you have already done. These are serious protection made from 1/8" thick steel diamond plate. The panels are made to fit stock rear quarters but can be cut down if your Bronco is "bobbed".
#5750 Quarter Panel Guards (pair) $129.99
C
ctowery
Wellington Nevada
I have seen the wild horse guards but i think the ones from Duffs are better since they are smooth and wont grab like Wilds will. The question still is for people who have run the Rubicon, Do I need rear guards ? , if so I will make some out of 3/16 as I think the others are to thin, just take a hammer and hit a piece of 1/8 and you will see what i mean
Rustytruck
Rocker pannel protection and then the lower part of the rear quarter pannel needs to be cut as you will crunch it but the sides are controled by driver as is the top so if you can protect the top you should be able to protect the sides it wouldnt hurt to have the bumpers stick out a little as rock feelers. You cant fight mother nature and if gravity grabbs you it doesnt matter what you armor. If you dent it then hammer out and armor it. Just attaching armor on the side of a body isnt going to do much with out support behind it instead of a small dent you get a caved in pannel. Also if you hang something on the body like that you better plan on serious rust prevention behind it because once wet the stuff back there is going to rust like a mother. 2 Things mess up a truck, impatience and bad luck. Minor damage is usually bad luck. The worst one is the Impatience and we have all been there. Should have retried a new Line or stacked a few rocks or went around it and how deep is that water? That maucho BS will get you 3 grand worth of damage real quick and the guys you are trying to impress are not going to chip in to fix it. If it is truly a toy then dont bother and just buy a big dent and drive it.
mtn_bronco
Leadville, Colorado
For the rubicon is a loaded question. Do you plan on using a bypass around the little sluice? If yes, then I don't think that you will need guards, just a little caution.
You are pretty well set-up... I know you think that the rubicon will be it, but you will be yearning for more. Guards are alot cheaper than paint and body work!
I would think rocker guards are the most important though.
The Rubicon too me (and this is my thoughts is just a bumpy trail with some beach ball size rocks thrown in. You can make it harder (soup bowl, little sluice) but if Jeep can take a stock liberty.....
BUT you are going to get bitten and want to go to johnson valley and more... Protect your sheet metal while the guards will fit it ;)
Howard
C
ctowery
Wellington Nevada
Thanks for the replys. I guess I will have to see little sluice to determine if I will take the bypass. This rig is not realy a extreme rock crawller at 5500lbs :eek: :eek: its more of a desert exploration truck. But I will look into some additional rear bumper extentions. I will be at FFF this weekend if any one cares to check out my bronco and give any additional Ideas .
BlackHorse
Here's one way to look at it. You can go at it without the protection and if you don't bash up the Bronkie your good. If you do bash up the Bronkie you can hide the damage with skies and quarter guards. Keep in mind all this stuff is much harder to install on a bashed up Bronkie.
IronBenderII
Like others have said... Depends on where you go on the Rubicon.
Here's the reality. You'll see the rest of us doing the hard lines and you will want to as well. When you do, it is a toss up. You might need them or you might not. Depends on your luck that day and how good of a driver you are.I have scraped my rear quarter and gas cap. I'm about to do a gas cap behind a door to keep from removing it like many do.
My advice. Do it. They look nice and hold up well.
-Jack
