question about installing a windshield frame* PIC UPDATE*
broncomitch
west jordan, utah
I'm going to attempt to install my new windshield frame tomorrow and have some questions. now in removing my old one i beat up my frame hinge pretty good, i was just outside trying to get it striate and moving freely, not to bad still needs work.
(Q #1) but i was wondering if i can weld the one part to the frame and use metal screws the hold it to the body, now im not running a seal between them so i figured screw heads would take its place as filling in the gap, ill also be running a soft top but its more less a trail top but im worried it will rip the screws out.
i dont have a problem welding it on but seeing as how my brother has taken the welder for his scout project we are working on it might be awhile till i can nick it back.
(Q#2) should i wait and order a new frame hinge?
TN1776
If you can countersink the screws or find screws with low profile heads I don't see any reason this won't work.
I bought a stainless piano hinge for mine when I painted my rig and I currently have it riveted (with likely more pop-rivets than what's needed) to both the windshield frame and the body. It feels every bit as solid as the original welded setup. I went with a stainless hinge because I've seen far too many EBs with paint flaking off the stock hinge and it always makes a good paint job look bad IMHO. I really like the looks of the stainless hinge unpainted too, and it was easy since everything was apart.
t.lay
Grayslake, IL
I used a stainless hinge - drilled and chamfered holes and used flat head screws - ended up a flush fit on the dash side - wish I'd done it on the frame side too.
Terkish
screwing it on should be fine. the 66 & 67's used screws from the factory to hold the hing to the body, and welded to the window frame. just as you described in Q#1.
broncomitch
broncomitch
west jordan, utah
[/URL][/IMG]
[/URL][/IMG]
got the new windshield frame on and my new hood, finished mounting the hood shocks and they work perfect! when the hood is about a inch from being all the way down the shocks lock the hood down. i spit on those silly kits lol
