Question about spring perches
roundhouse
Need to plate my banana shaped perches, was going to use some 1/2 in steel I have.
Any problem if the perch is wider than the spring?
The plates are about 5 inches wide, enough to drill holes and have the U-bolts pass thru also.
Should I cut them down to 2'' ?
May have to cut them down anyway, not sure I can reach in and weld them on with it sticking over the stock perch.
sstlaure
Bronco Slacker
Are you talking about the spring perch for the rear (shackle) or front (leaf spring) mount?
If it's wider (i.e. the replacement you find is a 3" wide), just run some plate on the Inboard (or outboard) side with a hole for the bolt and weld it in to take up the extra room. You don't want the leaf spring to be able to move laterally in the mount. I would think it could make for squirrely handling.
Make sure you keep the leaf springs nice and straight vertically so they don't bind up, if you need to you could move the mounts on the axle inboard or outboard depending on where your new perches line up.
R
roundhouse
Its the perch mount on the axle.
sstlaure
Bronco Slacker
There shouldn't be any problem with the perch on the axle being wider than the spring so long as it doesn't cause the U-bolts to be mis-aligned.
JBG sells new perches that would be the right width if you need them.
