- Aug 22, 2005
- 14,493
What is the oil seal?
Thanks for all your help!
Harmonic balancer oil seal
Been following your post and feel your frustrations to say the least!
How can I press on the lower timing gear? Replaced it when I saw how stretched the chain was. Do I need to get a degree wheel and find TDC etc, etc to set it or Can I just put it back on in the same location since the cam and crank have not moved?
Also... I have the same problem with the motor being forward 1/4" inch too much. How did you get your pan out? Trying to avoid taking off the headers motor mounts if possible. Track bar is off and trans front plate is loose but between the headers.
Thanks,
Kirk
i lined them up and put them back on in the same position so I should be OK. I need to find something to press the bottom gear the rest of the way onto the crank. I guess I will have to get out the engine hoist if I have to take out motor mounts tans x-member bolts and I may have to take off the headers to get to them. About to go give it another go.
