question for tire/wheel gurus
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
NOt often I ask a question but this one has me going
I have a chance to get (cheap of course) a set of new wagon wheels in 16x8 size. I also have a dealer who will give me a "unforgettable deal" on a set of Michelin 235/85x16 LT ltx AS tires.
The question is, will the tires fit correctly on these wheels or are they going to have issues with the wheels being so wide??
TOFIC
Tito
CB Fire Starter
Bakersfield, CA
I am definitely no guru but I have used a lot of tire combos. Those look to be 9.25 wide, should be just fine on an 8" rim. From my research it seems a lot of newer radials call for a decently wide rim fairly close to what the tire width is.
ztoolman44
Farmington, Utah
I have that size tire on a 16x7" wide rim and it looks like it would fit on a slightly wider rim no problem. The tread measures exactly 7" wide from outside lug to outside lug. Can e-mail a picture if you like.
brewchief
What are they going on? You realize that most 235/85/16 are D or E load rated right? That heavy of a load rating on an early bronco is probably not going to ride real good.
TOFIC
TOFIC
Redcliff Alberta
To the gentlemen with the "pink and pretty" Bronco (which I still like BTW) Thanks for the info, to bad you didn't win the draw!!
To the toolman pictures are nice!! walker@agt.net is the address.
To brewchief, yep I realize the load rating but I like the height to width ratio a lot and am willing to make sacrifices to get that tire height and width.
Anyone else?? haven't heard from you tire shop workers yet?
Anyone a service person in a tire store?? lets hear from you.
TOFIC
byson1
Nashville
The tires will fit fine. As Tito said they are 9.25" wide so it would be about the equivalent of putting a 30 x 9.50 on a 15 x 8" wheel. Your tire's sidewall height form the wheel is 85% of 9.25, or 7.86". If you add the sidewall height (2 times) plus the 16" wheel diameter you have a 31.72" tall tire. The perecte size wheel would be 7" wide but there won't be any issues with an 8" wheel. 6 years at Goodyear taught me a little.
ztoolman44
Farmington, Utah
Pictures are in the e-mail.
I have been thinking about using this size for my bronco project but I would need to find some original 16" wheels. I think they look perfect on a slightly lifted uncut.
