SpareParts
- Nov 13, 2004
- 5,592
My knuckle is wallowed out at the tie rod and was needing a fix.
I searched a little and found out what taper to go with. I talked to my local machine shop and they said they would weld the hole closed with a regular mig and ream the hole out.
I welded the hole shut and drilled out the hole first the tried to ream it out, it won't cut the weld? I used a step bit to start the hole and the reamer will clean the hole but after it is clean it stops cutting. I have tried using the slowest speed on the drill press, 230 rpm. I tried using a hand drill, no luck.
I since have search more and found out to braise the hole shut, I think that the braise would be pretty soft? I could drill the hole out bigger and then braise it closed again.
Any help??
David
Any help??
David
