- Jun 13, 2012
- 801
Hi all,
Got a few things that i need to figure out here prior to road testing
1. On my explorer 5.0 swap i hooked up the oil pressure gauge wire from the explorer harness to the OE bronco connector on the engine side that goes to the pressure gauge on the stock bronco gauge cluster. The pressure gauge is at max read out. Is there something i have to change/ add for it to read out correctly or is there possible something wrong with my gauge?
not sure i f something needs to be done/added combining stock and computer applications
2. seems like i bled all the air out of my HB power steering set up. drove the truck up and down the alley several times making sure everything is functioning. when parked it in the garage i noticed a good amount o f PS fluid on the floor. I popped the hood and found it to be leaking from the O bronco steering box top nut/allen bolt.
i rebuilt the box myself and i am wondering if i missed something- perhaps thread sealer on that bolt or maybe just need to my tightened to a certain spec? i haven't tried adjusting the steering yet from that bolt as i have yet to road test it.
JP
JP
