I prefer the centech harnes. If you run alot of accessories it might be worth looking at the painless harness. If you go with the centech I would replace your glove box with a new plastic one--nice cheap upgrade.
Leave the defroster ducts attached to the dash. Remove them from the top of the heater. Much easier that way. The cables are a little bit of a P.I.T.A., but if you look at them it will be obvious. One screw holds the housing and the cable loop goes over the defrost/heat lever. The temp control goes into the engine compartment and hooks to the control the same way.
Hell yes, label all of the wiring. It gives you something to reference and makes it easy for future use---sell it on Ebay or give it to someone on a budget in need.
Take your steering column, lights, and harness and lay it out in the living room. Familiarize yourself with everything and pre-wire it. They all use new and better connectors. Take the time to solder your connections.
Now is a great time to do the headlight relay upgrade as well.
It sure is nice having good wiring.
Tod
