QUICK ANSWER-Dash Removal
brutis72eb
South Carolina
Just need a quick answer-can you remove all the bolts to the dash and it come down-then you tackle the wiring or do you HAVE TO tackle the wiring then remove the dash? Thanks!:D :D
broncolove
The Bronco Ranch
S.E. Michigan
If you have your steering column out and all the dash bolts, Yea bring your dash down and do the wiring. Your dash will not come down though with out removing the steering column, heater cables, defrost ducts. After that just bring it down and check for snags.
todcolvin
It is definately worth pulling the dash down before wiring. Not only is it quicker, but it saves your back.
Case
nothing beats lying on you back, looking at the underside of the dash trying to un do wires. make sure to position a screw driver just right and lay on top of it.
tx1ton
Boerne, TX
Jeez that brings back bad memories! I was "touching up" some wiring so didn't need to drop the dash - amazing what funny positions you need to get into though when doing that...Doc thought it was hilarious to prescribe pain killers and muscle relaxants the next day too....:eek: %) :p
May not be that big a problem for the younger EB croud but us old farts tend to pay big time for such things ;)
brutis72eb
brutis72eb
South Carolina
Thanks for all the replies-you guys are QUICK:eek: I am going to be buying a Centech or maybe a Painless so do you think i should still label all the wiring? What all do you have to do to remove heater cabels and defrost ducts and column? Stupid Question?
tx1ton
Boerne, TX
My understanding is on both those harnesses the wires are well labelled every few inches or so - along with the color coding there's the stamped labels. I have heard very good things about the Painless #1080, looked into it but ended up patching things up for now...eventually will do the full harness but have other priorities first!
Good luck!
todcolvin
I prefer the centech harnes. If you run alot of accessories it might be worth looking at the painless harness. If you go with the centech I would replace your glove box with a new plastic one--nice cheap upgrade.
Leave the defroster ducts attached to the dash. Remove them from the top of the heater. Much easier that way. The cables are a little bit of a P.I.T.A., but if you look at them it will be obvious. One screw holds the housing and the cable loop goes over the defrost/heat lever. The temp control goes into the engine compartment and hooks to the control the same way.
Hell yes, label all of the wiring. It gives you something to reference and makes it easy for future use---sell it on Ebay or give it to someone on a budget in need.
Take your steering column, lights, and harness and lay it out in the living room. Familiarize yourself with everything and pre-wire it. They all use new and better connectors. Take the time to solder your connections.
Now is a great time to do the headlight relay upgrade as well.
It sure is nice having good wiring.
Tod
thesnake
Ditto on what TODCOLVIN stated, also, CASE, I remember going thru that when I installed the centech in my 73.
John
