Quick efi ?
74fiberglass
How does the fuel rail come off or the injectors? Is it the same
Spring type like the fuel lines? Next ? How do the injectors come
Out of the intake ?
Thankx
If you're talking typical Ford EFI stuff, the fuel rails themselves have a couple of screws fastening them directly to the manifold. Once you remove those, everything will just pull up.
Some remove the rails and injectors together, while others remove the rails from the injector tops, then the injectors from the manifold bungs.
I'm sure someone will chime in with some tips for doing it easier, but at the least you might have to twist things back and fort a bit to get them to all pop out.
74fiberglass
Yes I have the 4 bolts out for the fuel rails. I just don' t wanna pull up to hard and crack injectors . So I guess the rails just snap onto the injectors ( kinda)!!!
garberz
Bronco Influencer
Conejo Valley, Ca.
They're just held together with O-rings. The O-rings will get hard and brittle from time and heat, so most often you'll need to pull on them a bit. The injectors will be the same way, stuck in the manifold because of the O-rings.
If they're hard, then obviously a new set is in order.
If I remember too, they're pretty darn expensive for o-rings too! Of course, you buy 16 of them, so I guess it's just sticker shock from volume, rather than actual per-unit cost.
Good luck.
