Another advantage of at least starting the process now, is that you can better see where things go, an also if you try, can envision where things should go if different from where they have been.
You might decide to make changes, or you might keep many of the factory wiring locations intact.
If you’re making other changes like fancy stereos, lots of lights, or other things, now is the time to decide where to put those wires. Under the hood, maybe you want to route things differently or maybe even hide them.
So at least lay the harness out a couple of times in a couple of different ways, and start the process in your mind.
And no matter what you do, and no matter how complete the Painless harness is, don’t throw away your old wiring yet!
