brianlowry
I've run into an interesting problem. My radiator cap won't seal...
Tracing down some serious run-ability issues and it turns out that the radiator cap that I have isn't long enough the springs don't load to make a good seal.
I bought the radiator from genesis auto parts (no website anymore) back in 2010 and it's listed on the order receipt as a "ALL ALUMINUM RADIATOR - 0521AA - FORD BRONCO FULL SIZE ALL ALUMINUM RADIATOR"
Some searching has led me to find that it is a Silla 0521AA radiator, but because I can't find any other info on this specific model and I can't just go out and pick up a new cap for a 1976 EB, I'm looking for a needle in a haystack it seems.
I need the internals of the cap to be around 1" long, but most I've found are 0.75. Any that are 1" only are 4psi when I believe I should be using a 13psi?
Searching for caps for full size broncos only has .75 filler necks as well.
Any suggestions besides buying a new radiator?
Thanks!
Brian
Thanks!
Brian
