eds66bronco
i was wondering what the best method is for protecting the radiator from the fan. the one i see most often is the one jeffs and bc sells but i don't like the thought of sticking those plastic things through the core. has anyone used a sheet of expanded metal mesh or perfed sheet. wondering if this will give enough air flow? i was thinking of sandwiching it between the rad and the shroud. any thoughts or suggestions?
another question is protecting the lower front portion of the rad that sticks down below the core support. should this be covered over or shielded?
thanks
thanks
