radio install help
mp
Austin, TX
Did a search and found the original radio wire was yellow with black stripe.
Instructions said to hook the main power wire to the back of the ignition switch, which I did. Used the original yellow/black wire as the other source (key off memory), but I am guessing it does not provide any ACC off power since every time I turn off the EB and turn it back on, the radio forgets all the stations and goes to default. If I tap into the cigarette lighter for the memory/key off power, will it work? Any easier solution?
Viperwolf1
electron whisperer
Original radio power is switched not constant.
Cig lighter power is constant and already fused. It should be a blue-white wire.
mp
mp
Austin, TX
So I can use the original yellow/black wire for main power, and tap into blue/white for memory power? Thanks, Viper.
