Radius Arm and Coil Cup mounting
crutch
I am replacing C bushings and installing the Duffs heavy duty coil cups with Hellwig sway bar kit and the gap between the radius arm and radius arm bracket mounting holes are larger then the hole separation of the hellwig bracket. The coil cups have a slotted hole to give some adjustments but not the hellwig bracket.
Wondering if I’m installing the radius arms correct or if I need to close that gap. Anyone else encountered this and have any recommendations.
Thanks!
Bronco 4 life
Yakima
The radius arm cap should be flush with the radius arm that is too big of a gap it’s not tightened correctly from what I see in your picture.
There are procedures on the site on how to correctly install the c bushings so you dont get the “bronco lean” I would search that and read it Than go back and reinstall the bushings and caps correctly
Bronco 4 life
Yakima
The faces where the red arrows are should be sucked together but like I said search for the procedure on here or I believe wild horses has it on there site also good luck and stay safe
crutch
crutch
Thanks! I just watched the wild horses video and will take another look. I double checked the C bushing orientation before install but that doesn’t mean I didn’t screw it up. I may just need to tighten the bolts. Ha. Thanks!
DJs74
With new bushings, you'll have a pretty big gap at the start. I've had to remove the washer on the bolt in some cases just to get the bolts started.
The main thing is draw the bolts evenly as you go. There are probably many variations and experiences but I have found the criss-cross pattern works for me. Meaning, pick one as the starting bolt.. say top left, tighten few turns and go to the bottom right with a few turns, then top right same amount of turns, then finish up at the bottom left and back to the top left and start all over again. Just take your time and draw all the bolts evenly regardless of the pattern you choose.
At the end, both front and rear caps should be flush.
DJs74
Yep, and some good lubrication goes a long way. The go-to lube for a long time has been liquid hand soap, but any of the stuff specifically for poly bushings would work.
Just about anything would, but those two are the most neutral for poly and recommended.
The slotted holes are not there to mount the cups with the caps spread apart like that. They're there to accommodate not only slight variations (that should not be there, but might be anyway) but mainly to work with the wider spacing, or perhaps just larger bolt size of the full-size truck radius arm bolts.
Definitely gotta' suck those caps all the way down to tight. You can't worry about a bushing that is getting squeezed out as much as leaving a cap loose.
Some squeeze out more than others, and some not at all. But if you feel yours are just too splayed out when the caps are tight, let someone you bought them from know and maybe you can try a different brand.
Making the bushings squeeze out does not necessarily hurt anything. But it is annoying.
crutch
crutch
Thanks everyone. I’ve removed and tried a few times and closed the gap a bit but the bolts are extremely tight and not seeing how I going to get the whole way there. I used the grease supplied with the bushing kit and added extra but how much torque is required to get these all the way there? Any other tricks to get these sinched up?
crutch
crutch
Btw I’m not getting squeeze out of the c bushing yet but just having trouble as the bolts are extremely tight already.
crutch
crutch
Alright making some progress, starting to see some squeeze out with a breaker bar.
Are the threads clean and smooth? When you're getting some threading action, is it making noise or quiet?
Just wanting to make sure you're not fighting against a mechanical issue. The bushings themselves would sure make for a lot more torque needed to tighten the caps, but it's not so much you'd think something was wrong.
But those threads do get rusty and gunky from removing old nasty bolts the first time. So for sure make certain that you're not damaging the threads.
One way to do that is to remove one bolt only and inspect it. If it comes out smoothly and looks good, then goes back in easily to the last point you stopped, you're good and just fighting the bushings.
Good luck.
crutch
crutch
Success! Thanks everyone for the help!
