radius arm bent?
Apogee
Tangent, OR
Like Mark said, give us a little background so we can help you justify what it is you want to do rather than what you could or should do. If the goal is long-arms, then those look totally unsafe and unusable (but don't throw them away, I'm sure someone can make them work). If the goal is to stay on a budget and spend money only where needed, then those look totally fine and perfectly usable. See how this game works?
nickgp
Could they have a slight bend for alignment corrections done in the past? Not so sure they are unsafe. Curious.
BUCKWILD
Butte county
I have ran them worse than that bur that is bent. your call but is will get worse if you do much wheeling with it
D
diggs00
bronco will be Just for cruising no wheeling. Thanks for the info, i was looking at the duff arms but $$$$$. Glad I checked the arms before putting back on.
landshark99
Montrose, Colorado
You would be surprised how many are bent for one reason or another. I don't think you will have an issue with that little bend...
