Bent radius arm
joecardi
olmsted twp
Restoring a 75. Putting a 3.5 inch WH lift on it. I have a Drivers side Radius arm that is slightly bent towards the front left wheel. If I use this bent, will it effect my alignment or handleing? Can I straighten it or replace it?
stock1970
Olathe, Kansas
I would replace it, Seems you could find some stock arms cheap from someone that has upgraded there bronco to the long arms.
