Bent radius arm bracket?
1buckeyefan1
So i'm on my first frame-off restoration. Don't have any other frames (or experience...other than this forum).. but is it me, or does the passenger side radius arm bracket hole look like it's pointed outwards? It looks like they are the factory mounts, but the previous owner seemed to also mig weld everything in place in fear that it would fall off?
Is this normal, or nothing to worry about? I'd obviously like to fix it before paint if it needs it. I could always cut the mount off and remount, replace, or simply out out the donut and 'point' it forward?
Was about to march on, but worried about potential alignment issues down the road.
langester
MASTER OF MADNESS
Looking at the pictures it does look a little bit off. I am no expert, so I have no idea if this will mess with the alignment or not. If it was mine I would want to fix it though. Hopefully someone that knows for sure will chime in and verify. I think I have a set I cut off of a frame a while back (I will go look) if you need up needing one, your for the price of shipping. Let me know if you need them.
Good luck with it!
Steve
1buckeyefan1
1buckeyefan1
Good luck with it!
Steve
Thanks Steve, that's a very generous offer.. PM sent!
EricLar80
My guess is that it wasn't bent correctly at the factory and it was installed without a second thought. I am pretty sure they were all welded from the factory.
73azbronco
Nope, stock Ford of the day. My passenger side engine mount looks like the welder had a seizure during it's welding, then took lunch, and someone else finished it. Did you grind off the 500 or so weld splatter spots?
