You may want to check out the PSC Ram Assist install guide.
http://www.pscmotorsports.com/pdf/tech/single_end.pdf
very cool, thanks for the close up pics of the mounting pointsWest Texas Offload Red Neck Ram install complete!
I've bled the system. All seems to be working well. I haven't driven it yet.
Very nice. Exact same way I'm doing mine--even down to the WH riser bracket. I'm glad you posted pics as the only way I could see to mount the fixed end to the riser bracket was on the front of it which looked tight. Mounting it off the side of the riser bracket is way better.
Thanks!
Thanks for all the comments.
I trimmed each tab to fit into the 45 degree bend of the WH riser. The bottom one is just above the WH logo cut out.
Nice work and a good write-up/with pictures!!! Good luck at the "Falls"!!;D;D;D
I thought when a guy gets down with something like this, he's supposed to rattle-can-black everything under the truck??
Now how would I show off my new parts if I cleaned everything up??? %)
