Raptor liner prep question
NCSUWoj
Lynchburg, VA
So how far does one need to go to prep the bed for Raptor Liner? My plan is to get this cleaned up and shot with epoxy to seal it up nicely. Then planning to go back with Raptor Liner at some point once I get the remainder of the body work done on the rest of the body. Do I need to "feather" out these scratches on the bed floor as if I was going to paint it? Will they show through the Raptor like paint would? I don't want to waste a bunch of time sanding if it's not needed beyond just normal scuffing/prep work.
I had to take it pretty far to start with because of wonderful carpet adhesive that was on it! Man what a pain that was.
Any help or thoughts on this would be great!
SDBMtber
I had mine sand blasted so can’t compare exactly. But, I don’t think you need to do anything special. I put a couple coats of raptor on and did a rougher texture and I wouldn’t think you could see transition from paint to no paint like you have. I’ve seen some folks doing a smoother texture and maybe a single coat and maybe there’s a chance it would show through with that approach.
I think you’re fine without the extra prep..
Rocko1012
Bed looks good, Some Epoxy gives you 72hr to paint over it. After that you must be scuffed for mechanical Bond.
BronCowie
Old Timer
Vancouver, WA
It is not as revealing as paint so more forgiving of imperfections. When I was prepping, I called their tech support and got a very detailed direction on the phone in a conversation that lasted ~20 minutes. I would give them a call if I were you. :cool:
NCSUWoj
NCSUWoj
Lynchburg, VA
Thanks! I have gone back and forth about having it blasted but there just isn't much left that is original to blast! Lol. Just the bed floor really..
Good call on the top coat over epoxy. I may just wait and get everything ready to epoxy and then raptor it so I don't have to scuff it. I am planning to pull the tub shortly to get the underside of it too.
Great idea BronCowie. Hadn't even though of calling them. Thanks!
unimogger
Philthadelphia
needs a thorough degreasing with acetone or lacquer thinner before epoxy. And as mentioned, epoxy within a day or two of when you use the liner. If you don't hit that time window, you lose the chemical bonding between the epoxy and raptor liner.
sprdv1
REBEL
great idea, let us know how it goes..
look forward to finished product :)
stretch
Montgomery, TX
I don't know if this makes a difference, but Upol makes an epoxy primer that's compatible with their Raptor liner. I've shot the inside rear wheel wells when I replaced the rear quarters with the epoxy, and it shoots well. I also covered it within the suggested time frame, I think it was 48 hrs with the Raptor. The finished product looks great. Unfortunately I haven't tested it durability on the road, but it holds up great parked in a garage.
I'm getting read within the next week or so to spray the underside with the same combination. I'm going to add ceramic beads to the Raptor liner to help control heat transfer.
NCSUWoj
NCSUWoj
Lynchburg, VA
That is good to hear! I didn't know they offered a primer. Looks like it will be a good choice to spray first if specifically going with Raptor. The data sheet says you have 7 days to top coat with raptor. That is very convenient!
Let us know how it turns out on the underside. I am very interested to see the finished product!
Timmy390
Conway, AR
I had a couple of corners lift due to bad prep. Bout a 1x1 spot.
I prepped and prepped and prepped........Corners are very hard to get into to clean.
I cut out the lifted area and recleaned, hit it with some self etching primer and resprayed the area. Been good for a year now.
Spray the well used areas with extra coats. I have a couple small chips from the bed. Had a tire iron loose back there and after too many beers went for a night drive through the hunting lease. Looking at it, it chipped in some areas that were THINLY coated. The chips are very small.
I plan to respray the bed with a coupe more coats at some point.
Tim
stretch
Montgomery, TX
Timmy, I hear you on the prep. I've degreased and pressure washed and let it dry. I then degreased by hand in all the difficult spots, corners, up inside the tail light housing, etc.... Now I'm planning on hitting the impossible areas with a spot sand blaster followed by acetone. I'll miss something, but that's ok.
I'll post a couple of pics and an AAR after I'm done.
