Hey Everybody,
I’ve rebuilt and assembled the RAT transmission, the adaptor, and the Dana 20 - they all came out great and I’m in the process of installing the assembly today.
I’m using a hydraulic lift cart and ratchet straps to get everything aligned with the help of a friend, but getting hung up - the transmission face is an inch from the bellhousing. The smooth input shaft sleeve is into the throwout bearing, and the clutch release lever moves freely, so it’s not binding on that.
The angle and alignment look perfect, and we have wiggled and shifted the assembly every way I know how.
I know the pilot bearing is a small target, but the shaft is tapered - I’m surprised we didn’t stab it pretty quickly.
I have rotated the motor a tiny amount to try to line up the clutch friction plate splines with the input shaft about a half dozen times, in case that was not meshing.
Any ideas? I do have the tool installed to lock the RAT into gear - should I take it out and get the transmission into neutral?
And does anyone have a picture or diagram of what the shift levers look like when it’s in neutral?
Thank you! Hope y’all are having a nice Saturday!
