RustyButtons
Well, a brush in a pan of kerosene comes to mine. But my go-to for most of this stuff is Chem-Dip which is a carb cleaner. And it's probably what you've heard as not being good for the parts.
It won't hurt the cast-iron of course, and it won't hurt the brass if not left in for too long. But you probably don't have to toss any brass parts in there anyway. If there are any, just scrub them down with scotch-brite and some brake fluid.
The seals are what hate carburetor cleaners like Chem-Dip, but I've reconditioned seals to good effect when "ruined" by Chemtool and Chemdip stuff. I just soaked the swollen seals in water over night and they looked just as they did before.
Might not even be pertinent, since there should hopefully be new seals with any rebuilding procedure.
What was the cleaning solution and/or method used in the thread I linked to?
paul
I've followed a bunch of links that thread lead to - which have a lot of good stuff - but the only cleaning solution I can find mentioned is vinegar. And that is mostly aimed at removing rust internally when folks take the fittings off and the insides have rusty brake fluid. Jcckys mentioned his own challenges getting these little pieces out, but only mentioned vinegar as a cleaner. He mentioned he had some of these same challenges, but said he found most of these little bits were in bad shape internally once he got them out, and that he was going to see if he could source these small parts out of junkyard valves.
Most of the rebuild stuff I can find start with valves that are much cleaner on the outside.
