thomaspadden
- Jul 9, 2018
- 1
Im a novice and have some mechanical ability btw.
So i have a 1972, 302, 4 speed manual trans beauty! Love her to death. I had a mechanic install a Holley Sniper EFI. I removed both the old fuel tanks, main and auxiliary. I had them install a 23 gallon from Toms bronco parts with the in-tank high pressure fuel pump for the Sniper. It has a return line to main tank.
I want to reinstall my 9 gallon Auxiliary Tank and have it dump into the main tank. This is what i was thinking on how to do it.
Run the 3/8 fuel line from the Aux tank and "T" into the return line from the Sniper EFI. I called Holley and they said that the return pressure is approx 4 psi to the main tank. I was going to use a "dash switch" activated low psi inline carb pump (mounted to frame) to pump from the aux tank to Main tank when the main tank got to 1/4 full. I still have the fuel gauge switch on the dash to be able to switch from one fuel gauge to another so i know how much each tank will have.
Ideas? Will this work? anything im not thinking of?
Plain Talk for me please im not very techy.
