ILikeBond
- Jan 27, 2009
- 908
One of the things you forgot to note is there is suppose to be grease applied to the backing plate where the shoes rub. the adjuster screws should be disassembled and the threads greased and grease applied under the cap. Grease was factory applied where 2 pieces are assembled like the pivots for the parking brake. under the spring cups where they go up against the shoes. under the brake apreader bars and the wheel cylinder pins where they push against the shoes.
The factory used a grease called lubriplate. Use eithor this stuff or marine wheel bearing grease will do. Failure to grease these parts causes rust and wear on the backing plates. Without grease the brakes will also tend to pull and grab untill the brakes get fully loaded causing the Bronco dip and dive action when you first apply the brakes.
You are doing great keep up the good work. All the years on this site no one has tackled writing up this stuff Good For You!
Appreciate that advice. Since it looks like I'll be dis- and re-assembling anyway, I'll be sure to do this. I was a little amazed that there weren't simple instructions for doing this yet, either, but maybe its one of those things where simple enough for most people that no one has really thought about it. Sadly, I am on the novice side of things, so a "dummies guide" for these types of tasks is helpful for me, for sure.
