Rear axle bearing/retainer gap. Is this normal?
Raccol
I’ll try to explain as best as a can and apologize in advance if I’m using the wrong terms (pics to assist).
There is a gap between the axle retainer and the axle housing (pic1) where the bearing (Timken 514003) sticks out approx .125” beyond the bearing recess (pic2).
The recess depth is .7” (pic3/4) and the bearing width is .825 (pic5). The measurements are the same on both sides.
Is this normal? If not, how do I correct it?
Cowlesville, NY
Measure the backing plate thickness. The backing plate for the brakes goes on first then insert the axle and seal/ retainer plate.
That should take care of the gap.
Raccol
Raccol
Thanks for the prompt responses. I guess that's a "DUH" moment on my part. I'm converting to rear disc brakes and completely forgot about the backing plate.
