rdv350
I am trying to run the through everything on my bronco to get it ready for inspection and I am having problems with my rear blinkers and brake lights. My front blinkers work fine and my taillights work fine. But my brake lights do not work on either side and only my right side rear blinker doesn't work. I don't think it is my grounds because the tail lights and reverse lights work. I checked the fuse under the dash that is good. After I did some reading on these forums I am thinking that it might be the turn signal switch causing both problems. Is there anything else I should check before I trying replacing the switch?
Thanks,
Ryan
Thanks,
Ryan
