Rear Disc Brake Help Needed
blazinchuck
Ok, I'm trying to finish up this build, but I hit a snag with the rear disc. I bought the cj7 rotors,caddy calipers, and A&A weld on brackets. I've installed a full width 9". The rotors will not fit over the axle flange. I guess I eithe need to cut the flange down or the rotor out so they fit together. Someone also told me to just install the rotor behind the flange and use the lug studs to hold the rotor to the back of the flange. My only problem with this step, would be when(not if) I break an axle shaft. I would have to remove all the studs on both shafts and reinstall them and the rotoor onto the new shaft. What have you guys done in the past? I really need to get this done son, wheeling trip in a couple weeks. Thanks,Chuck
Pics would be helpful also,Thanks
Krawln68
Newark, CA
That is the way mine is. I got the BC kit and it requires the rotor to be mounted behind the axle and held on with studs.
blazinchuck
blazinchuck
how long are the studs and are the splines on the studs long enough to engage the axle flange from behind? I'm just worried about snapping a rear axle shaft, and them having to fumble with it. Would you have the part # for the studs and caliper hoses? Thanks,Chuck
