It appears I have an older set of rear disk brakes without the parking brake. Not sure which brand. Would the new style calipers with e brake fit on these brackets? What are the calipers with parking bake originally off of?
Before you install the el Dorado calipers chech out a few of the u-tube videos on setting up the e-brake. Many of the rebuilt calipers from the big chains dont mess with the e-brake components. Bc recommends using new calipers.
Check the pin spacing on the caliper...should be 5.47" [139mm) if it's a GM D154 metric caliper. These were commonly found on various applications from 1978 up into the 90's and possibly 2000's. The front calipers have 2.50" piston diameters and appear to be what you have, and could have easily come off of a G-body, S10 or 3rd-generation F-body application.
The parking brake equivalent to those calipers would be the 1979-1981 Firebird T/A rear calipers or the 1978-1985 Cadillac Eldorado applications. TSM offers new castings of those calipers complete with hardware IIRC, noting that many of the auto parts store remanufactured units will not include the levers or springs bolted onto the inboard side of the caliper body for the parking brake.
https://www.tsmmfg.net/new-not-rebuilt-small-gm-rear-calipers-3110.html
Ruffstuff also has brand new El Dorado calipers
https://www.ruffstuffspecialties.com/R2262-A.html
Those are the 76-78 models (big ones) that won't fit on the OP's brackets.
Todd Z.
so i found a contenental mark V that has rear disks in a local yard. i have read these fit. or would are the eldorado calipers better?
too bad none of these swaps are newer aluminum calipers.
hmm. things to think about for sure. pulling from junkyard is pretty cheap rather than finding new eldorado brakes. but if the tech is old maybe not worth getting. maybe wait for info on a newer conversion to come out.
