I only looked at the pics Steve, but does it say anything about double-cardan shafts in the text? I'm thinking no, since the later Broncos probably didn't use them anymore (that right?) and so might not be covered in the TSB. If they did though, I'll go back and read the whole thing just for the info.
Paul,
The idea with a double cardan is to "split" the angle. If you have a 8* angle at the trans, you could use the double cargan to give you an operating angle of 4* for each joint in that double cardan joint.. **
This info may not be 100% correct.. I'm learning a bit more about the double cardan here.. I've recently found this quote:
Since a double cardan or CV driveshaft cancels out the angles on that end, you need to set it up so the non-CV end operates at 0 degrees. It's as simple as setting it up so the pinion is in line with the driveshaft. In reality, we've found that on leaf-sprung vehicles, it's best to set the pinion 1-3 degrees lower because the pinion will climb under load. Vehicles with link-type suspensions can set the pinion to 0 degrees
.... So, it may have a little more to it than a 2-pc design would...
On a live axle, live Steve's TSB shows, you want an operating angle of at least 1/2* in order to assure needle bearing rotation. But, you want to keep that angle to less than 3* for maximum life.. In the world of lifted, short wheelbase, Bronco's, thats not always possible.. The most important thing is that the operating angle of each joint is as close to equal as possible and the shaft is in phase. This way, each rotation of each yoke variation will cancel itself out..
BTW, simply changing pinion angle will not always correct the issue.. The pinion angle is dictated by the transmission output shaft angle.. They should be on the same plane, or a D/C joint will be needed to split the front angle to get them close..
I'm a bit surprised though that true CV joints are not more popular.. They can be built to be pretty strong and they do not have speed variation when the angle changes, hence the name constang velocity.. Ford experimented with these on the Bronco II and everyone uses them on FWD as well as 4x4 half shafts..
