Rear end dimensions
lancepr
I am rebuilding my 68 bronco and apparently it has an 8 3/4 rear end, not a 9"
What are the dimension of the 9" for overall length, and center to driver side and center to passenger side. Drivetrain guy is telling me the dimension I am giving him are wrong!?
video of me and my son working on the bronco! Only good thing to come from covid so far!!
https://youtu.be/vA5gFyguC64
Viperwolf1
electron whisperer
It may have an 8 3/4" ring gear but it is a 9" housing. All early bronco rear axle housings have the same width to the housing ends no matter what year or bearings or brakes they had. That measurement is somewhere between 53 3/8" and 53 1/2".
You have what is known as a 9" rear end. Ford played a few games over the years and put in ring gears that were slightly smaller (like you found) and sometimes a little larger. But it is still considered a 9" rear end. Any aftermarket 9" 3rd member will go right in. Your 3rd member will go right into any aftermarket 9" housing.
The only thing Ford offered that looked like a 9" but wasn't a 9" was the 8" rear end. Typically found on the normal low HP V8 mustangs of the late 60s. At a glance it looks like a 9", but 9" parts won't work. There was never a truck version of the 8"
L
lancepr
OK, thanks. I am taking the whole rear end up to the shop in the morning, I will let them know about just swapping the 3rd member.
It is 53.5" long
