Rear Seat Access Project
jba6555
I recently decided to get rid of my Front Bench with a rear seat combo, as it was way too difficult to get in and out of the back seat. That and I wanted headrests for safety in the event of getting rear-ended.
So I picked up a set of seats from Tom's. The Tom's seats look pretty good, and they provide the headrests I wanted... But they dont improve the rear seat access much at all. So I went to work on a solution.
I picked up a passenger seat base from a 1990 Extended Cab Ranger (from before the third door existed), the same as the mechanism in a 1990 Bronco II, like I used to have.
I then ground off the rivets holding the angled front mounts off, and removed those mounts.
I ordered the Passenger Seat Storage Cubby from Wild horses to give me a flat mounting surface for the seat bracket.
I took the slide mechanism provided by Tom's off of the seat. The Ranger bracket lined up with the forward mounting holes on the seat perfectly. I marked the seat where it needed to be drilled in the rear for the mount. Then drilled and tapped it.
Here it is installed:
Here it is with it tilted forward:
And here it is slid forward until the headrest hits the windshield:
A massive improvement in access to the rear seat!
It is a relatively straightforward adaptation. If any of you are looking for better rear seat access, I would encourage you to give this one a shot.
J
jba6555
I still need to make a good handle for the slide release, and put the Toms hinge covers on.
Those look great! Of course, the bench seat sure was cool as well. Just not very practical for most of our uses in the standard age.
Still… Vintage is fun.
J
jba6555
My rear passengers just jumped over the rear quarters
The roll cage made that pretty much impossible. My kids would go over the tailgate when I had the 66 rear seat in it. Once I switched to the Toms rear seat, the seat was too tall to crawl over.
Taking any Adults back there was really out of the question.
J
jba6555
I keep putting my arm up to rest it down the length of the bench seat top, like I always did... But there is just air there. Nothing to rest my arm on. I miss that!
J
jba6555
I finished up the project today. I needed a small handle for the slide release. Well I found a plumbing valve with a white handle on it that was just perfect. 1 little bolt with some loc-tite and it is all set.
J
jba6555
I have a video of it in action but When I uploaded and click post reply the video does not show up.... Any ideas on why?
Johnnyb
Flagstaff
I wish I could do that. My cage has full X-braces behind the front seats. Kids need to worm out the back, but they are flexible. ;)
But then they get older and less flexible.
Then again, that’s their excuse to get dad to build them their own Broncos. Or heck, just take yours!
J
jba6555
They changed the upload settings so I could attach the video now. I have to say it works really well.
  • IMG_5975 (1).MOV
    29.1 MB
snick
Looks great and nicely executed. If I ever choose to go with aftermarket seats, I’m going to keep this in mind.
Question - Is that a Family Bailie Bilt cage? It has what looks like an extra bar across the floor that you mounted your seat belts to. Do you happen to have a pic of your cage showing that section and how that extra bar is incorporated into the cage? I’m about to pull the trigger on a Bailie Bilt family cage and trying to think about all aspects before it gets painted and installed and then it’s too late. Thanks in advance.
J
jba6555
Yes, that is a Bailie Bilt. I will take some pictures for you when I get a chance.
It was a pretty simple addition I did myself. I got a couple of domed caps to weld on the ends for a nice finished look. Welded those in and ground them smooth. Then saddle cut 2 pieces. Tacked it all together test fitted it in the bronco then pulled it back out and welded it all up.
samamarshall
Nice work! I need this for my build for sure. Now where to find those seat brackets...doubt I'm going to find those in a pick N pull
J
jba6555
I have a threaded bung for the retractor base.
Gsav69
This might be the best mod I've seen. Do you have anymore pics or learnings youd be willing to share now that youve used them for a while? Id like to borrow this idea if you dont mind. Absolute great work.
Gsav69
Im going to resurrect this thread. Although I was unsuccessful in connecting with @jba6555 his efforts helped me a great deal in getting a seat frame that offered the slightest bit of room for someone to get into the back seat of my u13 roaster with fiberglass door inserts. Id like to add a center console and without a solution like this, using my back seats would be annoying and difficult.
For starters, I couldn't find a seat frame from an extended cab ranger but I was easily able to find one from a 90s f150 extended cab which did the trick. I would recommend welding in the floor cubby if possible, whereas I bolted in mine. I used grade 8 bolts and fender washers to secure it. I cut off and welded the mounting plates in red, back onto the four inside corners of the bottom rail of the frame so I could mount the seat frame as low as possible while allowing the forward and back slide mechanism to clear without issue. This also allowed me to put bolts closer to the center of the cubby. While fitting it up, i ground off a few unneeded tabs here, reshaped the white valve handle he mentioned and when all was said and done, I ended up here. Please excuse my commentary in the video and im happy to help anyone if they'd like to embark on this project which is both effective and can be done reasonably cheap. Im super happy with it and thankful for jba's detailed post. My last recommendation might be to buy both the driver and passenger side frames and modify them both so both seats will have the same lever and sit at the same exact height. In my case, if you have OCD and/or look closely, you'll notice there are differences as my driver's seat has the standard toms slides and tbis seat sits a tad higher. Hope this helps even 1 person.
  • VID_20260418_095139.mp4
    9.4 MB
