I have new rear shock mounts and body off the frame. Wanted to know what the location of the mount should be because they are different side to side. Also the new mount have a pretty big gap.
I was planning to just replace the old one with new ones I got no dual shocks. I was thinking of maybe running these shocks Bilstein 5165 Shock with Reservoir 360/80, 24.4" Extended, 14.6" Compressed or do you need a different set up?Are you about to replace your old ones with new, or are you adding duals?
No I got them from wildhorseDid you get those from bronco graveyard?
Yeah I was thinking of maybe putting a plate on the back of the mount or cutting the tab off on the back and rewelding it.Don't have a measurement for you yet, but the gap "might" be taken up by a couple of whacks with a hammer. No, you should not have to do that to a new part, but it looks like it might be able to take care of the gap.
But don't base it on the position shown, but base it instead on the exact location you're going to mount them. In other words, where the old ones are now.
Should not be any difference, but it's yet another "just in case" kind of thing. Just in case there are variations between the two locations.
Maybe others have suggestions. Measurements should be forthcoming.
Not surprised yours are in different locations. Not sure if that was on purpose, or just the standard operating procedure of not measuring carefully. We see it all the time with frame appendages.
Yeah was thinking of doing that.Just bend the tab in a little , if the frame is rusted bad slide a plate in there and fix that problem.
This is what I’m doing. It was rotten behind my shock mount. So I cut it out and welded a flush plate in.Yeah I was thinking of maybe putting a plate on the back of the mount or cutting the tab off on the back and rewelding it.
Ok so would you put them in the same spot or split the difference and maybe make them even? I know these trucks are not build with precision.
Yeah thats a good idea plus the new one look alot smaller then the original one.This is what I’m doing. It was rotten behind my shock mount. So I cut it out and welded a flush plate in.
But since the new mount is to wide, I’m going to just weld in an 1/8 in plate in from spring perch to spring perch.
I figured that will only strengthen my repair and hopefully not as noticeable as a square plate sitting on the side of the frame
No I don't have shim under the leaf springs. I got a surprise under the mount like you had.Side question. Do you have 6 degree shims under the leaf springs?
Yeah maybe the driver side is the one that is more forward.Yes, it’s not critical. However, it would still be nice to know whether that is a factory bem, or factory on purpose.
Maybe the driver side is a little forward to clear the fuel filler hose or something like that.
Which side is in which direction on yours?
Ok i don't have a bumper yet. Why do you have a Phillips screw on the one side?68 frame, measured from back bumper, both sides about 20-9/16" to center of shock mount, at outboard end.
