Rear upper shock mounts
turbotim2
____________
Are there any heavier duty rear upper shock mounts out there? I replaced the originals with the available replacements and have now broken both of them off. And I don't leave the road. Thanks!
Madgyver
Bronco Madman
1969
Reno, NV
You replaced the originals and they broke off? Did you weld them on or what?
blade
Maker of sharp things
Santa Fe
Also check your shock length and make sure the shock isn't bottoming out.
spap
You might need some axle stops bump stops for the rear
Okie69
If you’re breaking the mounts off and you don’t leave the road something else has to be going on. Unless you’re regularly jumping railroad tracks maybe 😂
