Rear speaker solutions
DaveLev
I understand a lot of you have done some cleaver things with speakers in the rear of the early bronco. I am considering putting 4 speakers in the rear, or 4 speakers in the rear and an 8" un-ported sub.
I am not sure if I should go 6x9, 6.5" round, or 5.25" round because I have not measured yet (bronco at work with wife; I'm at home).
I am a do-it-yourself kind of guy, and neighbor does woodworking, and I may want to build something myself.
I have a soft top and 6 point roll cage (not family style 8 point yet) and a rear seat. I also have old diamond plate side panels that work good below the bed rails so to speak. They don't hit the soft or hard top.
I'd love to see some pictures or links to pictures.
I will be doing CrawlTunes cans for the front.
I may skip doing the rear 4 speakers and sub if it is too much effort or if I can make the crawl tunes cans work for the rear (tough without family cage).
tasker
all knowing of nothing
NH
I used behind the seat Ranger speaker boxes with marine grade 5 1/2" rounds......mounted to the rear inner 1/4's
jmangi62
Why not just cut a hole in the diamond plate panels and mount you're speakers that way.I have the same set up as you and thats what I'm doing.I put 6x9s in the panels and 2 small 5in. speakers below the dash,nothing fancy but it'll work for now,just to get some tunes in the rig.I did have to get spacers to fit in between the panels and speakers,they're 1in. thick and I painted them black.Worked out great,good luck. Jim :cool:;D;)
68stang73
I have been thinking of doing a 10-12" JL or Rockford sub in the rear. Use the whole rear quarter/wheel whell area for the enclosure. Or I might use another powered 12" Rockford sub enclosure with built in amp. I have one of those in my Heep and 79 f150. That thing pounds hard.
D
DaveLev
The 8" rear sub is what I want to do on the passenger side in the rear.
Were those 6.5 or 5.25 ranger speakers (not sure what a ranger speaker means)?
I may cut into the diamond plate, but not sure on backspacing until I pick out some speakers.
Thanks for the ideas - more pictures the better.
The MTX one sits too close to our heads in our aftermarket seats, so that's out. Really wanted to go that route, but not worth raising the roll bar to do.
bronconut73
Don't know what kind of music you listen to but the mere fact that you want a sub means you understand the need to fill in the lower spectrum of sound.
This is good. Don't need to convince you of that.
Consider moving up to a 10" or 12" sub.
Back in the day if you wanted "tight" rock and roll bass you needed a smaller sub like an 8", then a 12" or 15" for rather low bass (no not just boom).
But in today's audio market you can have your cake and eat it too.
The only exception to that rule is if you want a sub that does everything well, you usually need to step into the 10" and 12" size. They can sound really tight and still hit low, whereas the 8" will struggle with that. The exception being extremely high end 8" subs or custom enclosures designed around that particular 8" sub.
Not to over complicate things but it sounds like you take sound pretty seriously, so try to fit a 10" or 12" sub in there.
Oh and by The way....
The diamond plate is fine but you will need to spend a small fortune in Dyna-mat to quiet it down. The best backer board for a sub is mdf particle board as it has no resonance. Even plywood will vibrate.
