Folks let me say up front that it's been a long time since I've done this type of suspension work. Maybe I've gotten ahead of myself in the re-assembly. The problem I've run into and need help with. I've changed out my rear springs, I have them in correctly with the military/double wrap to the front. I've got the passenger side of the axle bolted up loosely with the u-bolts and spring plate. Everything is fine on that side. On the driver side the center pin in the spring pack is not lining up at all to the hole in the spring pad on the axle. It's about 1.5 inches off center in two directions. The rear springs are already torqued to spec, should I have loose assembled everything before tightening it all up. I took a couple of pictures they are not the best but it will show what I'm up against. In the one picture the shiny spot you see is the hole in the axle spring pad.
