AZ, one of the worst places for that glue. But I make it work. Took some mistakes to learn, but finally got it to stay.
Follow (most) of the instructions.
Mark the outside with tape so you get the right spot. Mirror in the wrong place sucks.
Clean. Razor blade. Use the supplied cleaner exactly like the instructions say to.
Put the drop of glue on the button and place it on the glass. DO NOT MASH. Light press only. A little masking tape to hold it in place. If you mash you squeeze most of the glue out and it WILL fail. This is the biggest mistake made.
The one instruction to ignore, "ready in 30 minutes". BS! Park in the sun for a full day. Even an overcast day. Glue is UV cured.
After a day slip on the mirror and snug the screw. Doesn't need to be real tight, just snug. Don't want to flex the bracket.
Doing that with the normal parts store mirror glue I have not lost a mirror in over 15 years now. Even the stuff that sits in the sun for years holds up. The learning curve to figure this out, I got to install the same mirror several times until I figured out what was failing and corrected it.
