I'm in the middle of a frame off professional restoration. So the whole brake system is going to be new. The rear brakes would lock up 20 yrs. ago. Not knowing the problem was the combination valve, I installed a Kelsey Hayes adjustable metering valve, from Ford Racing, on the rear brake line. That worked, but now I know the combination valve was the problem, so it's time to rebuild or replace. If the rebuild can't be done, I'll have to go with a Wilwood adjustable combo valve. I won't take a chance on a Chinese unit. When I got the OE valve apart, I could see there were no moving parts that could move at all. With the rust free Az. environment this thing looks new. It just won't work yet. So I'm off to the junk yard.
