I am about to drop the front and rear suspension so I can get my frame blasted and painted. Got one rear body mount to fix and one section of rot by gas tank. I'm looking to get the full poly bushing kit from WH I'm trying to decide what to do with the axles. They are both spinning and nice and quite. I at least want to replace all the seals and get new flood in them. Should I be doing anything with the bearings? Everything I see online says the master kits aren't worth it if the bearings are quiet. So I'm looking for advice. Really don't want to spend unnecessary money. At the same time I want to clean up the front and year end and be done with them for years
Any advice? The rear is staying drum but I will be looking into what knuckles I need up front to go disk. But I think I can rebuild the front and just swap knuckles later
