This times ten.
Also, I had a few GM guys call me after wiring Fords looking for help. This was touched in a previous post regarding Ford's cylinder numbering vs. GM's odd and even.
GM's spin clockwise for dizzy, Ford's are CC at least where we're concerned.
Also, switch out the HB and flywheel to the proper balance. Your fillings will thank you. I've run across this several times on older swaps, even a newer 5L. Rev the car up and she vibrates like a driveshaft out of balance, yet the vehicle was stationary.
I've also had a 351 come in running on 4cyls in the past, turns out, after doing what mck recommended, I found out someone installed a different cam with 302 order. Never assume displacement dictates the firing order, someone may have swapped cams. Only way to know for sure is to turn the engine over without the valve covers on it.
